Having a lot of trouble pulling in the snow... tires?
Old Jan 21, 2009 | 08:18 PM
Common's Avatar
I saw a small Dakota water dept. truck buried in the snow locally. It was in a lot that was unplowed with about 8" on the ground.
I pulled in the lot, and struggled to get to the truck.
Finally backed down an incline, not too steep... used a 6ft. tow strap.
Had her (it was a woman driving) put it in neutral.
4 hi, and was spinning all 4 - barely moving.
4 lo and had her put it in reverse - same amount of trouble.
I have 245/75/16 BFG Commercial E's
60PSI in them, 80PSI MAX...
Last year with my balding 285 BFG AT's I pulled everything.
Now I'm scared to try as I can't grab anything.
Old Jan 21, 2009 | 08:33 PM
ofcmarc's Avatar
You need a concrete bead liner...... That'll put some weight on the tires and make them bite more.
The "e" rated tires are a harder compound than your old "ATs" They won't grab as well when they are cold.
Old Jan 21, 2009 | 09:04 PM
jamesbfishin's Avatar
Dropping the air pressure a little for a bigger contact patch might help. Not familiar with that model tire, but the tread pattern might also be part of the problem, is the tire siped?
07_Ram
Mar 19, 2012 02:23 PM
1320
May 29, 2009 10:24 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Hoss
Dec 10, 2005 02:30 AM
