DTR Breakroom 12.13.09-12.19.09 (The same old breakroom with some flying stuff)
chaikwa.
I don't think so. My buddy in Ohio only fired his twice a day, used big chunks of wood, nothing under 10" diameter. With the JCB and rear grapple you could process allot of wood fairly easy. You'd need a self contained cut off saw. I also have wondered why someone has not taken the old German technology of running an internal combustion engine off the wood smoke and added a generator to the mix.
chaikwa.
From what I understand there can be major differences in brands. My Ohio buddy moved to Kansas a few years ago and installed a wood burner there. It got totaled last winter by a sheet of ice sliding off the garage it was next to. The same company installed both units and they claimed the new one would use less wood than the old one, they were right. The old unit burned more than the one he had in Ohio. The new one used about 30-40% less wood. The only difference was the setting on the thermostat that controlled the water temperature in the heating unit. It was about 10 degrees cooler so the draft wasn't open as much, so the wood lasted longer. There was no difference in the heat produced in the house.
Rick> Your Right On The Ability To Run Engines On Wood Gas >
Probably Something In The Unused Gasses That The Epa Finds Objectonable>
However They Are Building Plants Up Here To Make Gas From Wood -
And We Have A Wood(chip) Heated Generation Plant 10 Miles North Of Me -( Always A Huge Cloud Of Steam -mainly) Comming From It Year Around >
They Use Tops Of Trees From Clear Cuts (chipped ) To Run It >
