Chrysler T&C code P0480
Old Dec 2, 2006 | 12:17 PM
dssimecek's Avatar
From what I have learned on this site was able to pull the code.
Had the Check engine lite on. ON the 2005 Chrysler the key trick works to pull the code, but have to on-off-on-off-on fast for the code to appear.
From what I have found that code is: P0480 Cooling Fan 1 Control Circuit/Open(Low Speed Fan Relay).
It appears to be running OK, tempatures seem ok. Daughter reports the odomiter/trip indicator did a snake dance yesterday morning.
It is about due to go in for service in a few hundred more miles so will have the dealer check it. It has an extended warrenty.
Old Dec 6, 2006 | 10:49 AM
dssimecek's Avatar
Update:
Problem with the cooling fan. The wire was chaffed thru, and shorted to ground on the A/C piping. The extended warrenty would not pay for it. Reason the chaffing was caused by the wiring harness not run correctly after a repair. The water pump was replace at 39K miles and the extended warrenty paid that bill. So the knew there was a repair in that area.
efil4ynot
Aug 28, 2014 02:15 PM
043500QC
Aug 28, 2007 03:12 PM
Jnoble
Jan 10, 2006 03:38 PM
SuperGewl
0
Apr 22, 2005 09:10 PM
