Chinese trailer wheel bearings. How much confidence do you have in them?
I just bought a used 5th wheel camper, 27ft & decided to repack the wheel bearings, before I use it on a 600 mile trip this weekend. Well, I saw the grease seal was dry as bone & leaking, so I went the full route and got new all 4 new bearing & seal "Kits". I was in a jam as time was short. The trailer dealer gave me Taiwanese make bearings..don't remember the name..but, has anyone had good luck with Chinese trailer wheel bearings? Yea, timkin or other American bearings would have been the best, but could not wait a couple days for them to get here.Chinese trailer wheel bearings. How much confidence do you have in them?
About as much confidence I have in my Chinese trailer tire that separated just sitting in my driveway...
First off, Taiwanese or Chinese? Believe me, there is a difference.
I haven't heard anything bad about Taiwanese bearings. Also, do not assume just because it says Timken that it isn't still Chinese... |
How far from civilization are you that you couldn't walk into a bearing house and buy something decent like NSK,or NTN Japanese bearings?Mainland China sucks and Taiwan is not far behind.If your desperate call 'em in and over nite or 2nd day delivery.NOT bashing you,just passing along hard learned lessons.[laugh]
Chinese bearings was probably the original bearings to begin with.
(Post 3128968)
If you can't get any other bearings in time, they should work fine for your 600 mile trip. You could always pull them when you get back and check them. If you aren't comfortable running them, order what you need to replace them. Me, I would trust them for the trip, at least.
What he said. Than if you are going to be going on longer trips I would get some good ones.
Originally Posted by klx650a2
(Post 3128936)
Chinese tires will last forever.......
If you don't put them on a rim. |
when it comes to bearings. Just get Timkens or SKF and be happy.
(Post 3128968)
I put all 4 wheels in last night...yea, the new ones say made in China ....the ones I took out say made in Romaina!!! huh?? yep..Romaina!! thanks for the comments..that is what I was looking for!
Originally Posted by RoadDiesel
(Post 3129119)
I have seen some decent stuff out of eastern Europe. they can be a PITA to work with tho. |
If you use the trailer much get get a couple of spare bearing kits and a small tub of grease to carry with you.
And a pair of rubber gloves so your wifes hands wont get too greasy.
