Blacking out taillight lenses
Old Aug 21, 2005 | 04:19 AM
2500CTD's Avatar
Unhappy Blacking out taillight lenses
I got an idea and need to black out part of a taillight lense. What would be a good thing for this? Just paint? What do they use on those hitch braklights that have the designs in them? That is what I'm looking for. Originallly the sticker guy I went to made the design up in black vinyl and the design was clear vinyl. The black vinyl wont block the light.
Old Aug 21, 2005 | 05:32 AM
Jim Lane's Avatar
Do you want to put it inside or outside the lens?
You could use some good electrical tape like Scotch33 or if it needs to be wider, go to a plumbing supply and get the gas pipe wrap tape. It's about 2" wide and thick so light will not go through it.
Jim
Old Aug 21, 2005 | 05:56 AM
2500CTD's Avatar
I cant get to the inside. Wont the tape peel after a while if its on the outside? Actually it is going on one of those hitch brake light things. Haven't figured how to get it apsrt to change the light, or else it would be on the inside.
Old Aug 21, 2005 | 06:40 AM
Jim Lane's Avatar
The pipe wrap tape is fairly thick vinyl not sure how many mil.
It should work.
Jim
Old Aug 21, 2005 | 08:43 AM
2500CTD's Avatar
Only thing is then I would have to cut the design out into. If I were to use a spray type of thing, I could slap the sticker on, spray and peel the sticker off, leaving the unpainted lense in the shape I wanted. hmmmmmm
Old Aug 21, 2005 | 11:11 AM
doodah's Avatar
Ive heard of some guys using the spray on window tint or something, I will see if I can find the post from DTW
Old Aug 22, 2005 | 01:41 AM
2500CTD's Avatar
Cool thanks. I found how to take it apart, but all the "refractors" for the light are on the inside and it wont stick so its gotta go on the outside.
waldersha
Aug 13, 2008 11:36 PM
danalex
May 25, 2008 04:56 PM
cluckmaster
Jun 27, 2007 01:00 PM
doomgaze
May 5, 2007 12:59 PM
Katmandu
Nov 8, 2006 08:30 PM
