being punched in the testicals
Old May 10, 2009 | 02:36 PM
powermad's Avatar
being punched in the *********
my dr office is closed today and i need some first hand input. i got punched in the boys yesterday and i am still feeling a lot of pain in my left ******** and lower abs. my question is have you guys ever been hit there and the pain last more the a couple minutes. because ive been hit there before and the pain goes away but not this time. any help would be great or tips on recovery
Old May 10, 2009 | 03:06 PM
madhat's Avatar
Administrator/Jarhead
Go to the emergency room?
Ice?
Hope that gets better...
Old May 10, 2009 | 03:07 PM
rockcrawler304's Avatar
You may have ruptured something. If your still in pain then something is not right.
Any swelling?
Old May 10, 2009 | 03:12 PM
RonA's Avatar
Here's a website with some of information on the subject
www.boxingwithmidgets.com/uppercuts
Old May 10, 2009 | 03:19 PM
Totallyrad's Avatar
I did a little quick research and have included an excerpt from one article below. If you will Google "testicular injuries" you'll find plenty of reading. It seems the general rule is if the pain and/or nausea lasts for more than an hour or so, get to the doctor!!!!
It hurts just to think about it. A baseball takes an unexpected bounce when you're crouched and waiting to field a grounder, an opponent misses a kick on the soccer field and his foot has only one place to go, or you're speeding along on your bike and you hit a big bump. All result in one really painful thing — a shot to the *********, one of the most tender areas on a guy's body. Testicular injuries are relatively uncommon, but guys should be aware that they can happen. So how can you avoid injury?
How Testicular Injuries Happen and What to Do
If you're a guy who plays sports, likes to lift weights and exercise a lot, or leads an all-around active life, you've probably come to find out that the ********* are kind of vulnerable and can be injured in a variety of ways. Because they hang in a sac outside the body (the *******), the ********* are not protected by bones and muscles like other parts of your reproductive system and most of your other organs. Also, the location of the ********* makes them prime targets to be accidentally struck on the playing field or injured during strenuous exercise and activity.
The good news is that because the ********* are loosely attached to the body and are made of a spongy material, they're able to absorb most collisions without permanent damage. *********, although sensitive, can bounce back pretty quickly and minor injuries rarely have long-term effects. Also, sexual function or sperm production will most likely not be affected if you have a testicular injury.
You'll definitely feel pain if your ********* are struck or kicked, and you might also feel nauseous for a short time. If it's a minor testicular injury, the pain should gradually subside in less than an hour and any other symptoms should go away. In the meantime, you can do a few things to help yourself feel better such as take pain relievers, lie down, gently support the ********* with supportive underwear, and apply ice packs to the area. At any rate, it's a good idea to avoid strenuous activity for a while and take it easy for a few days.
However, if the pain doesn't subside or you experience extreme pain that lasts longer than an hour; if you have swelling or bruising of the ******* or a puncture of the ******* or ********; if you continue to have nausea and vomiting; or if you develop a fever, get to a doctor immediately. These are symptoms of a much more serious injury that needs to be addressed as soon as possible.
Serious Testicular Injuries
Examples of serious testicular injury are testicular torsion and testicular rupture. In the case of testicular torsion, the ******** twists around, cutting off its blood supply. This can happen due to a serious trauma to the *********, strenuous activity, or even for no apparent reason.
Testicular torsion isn't common, but when it does happen, it most often occurs in guys ages 12 to 18. If it occurs, it is crucial to see a doctor as soon as possible — within 6 hours of the time the pain starts. Unfortunately, after 6 hours, there is a much greater possibility that complications could result, including reduced sperm production or the loss of the ********. The problem may be fixed by a doctor manually untwisting the ********. If that doesn't work, surgery will be necessary.
Testicular rupture can also happen, but it is a rare type of testicular trauma. This can happen when the ******** receives a forceful direct blow or when the ******** is crushed against the pubic bone (the bone that forms the front of the pelvis), causing blood to leak into the *******. Testicular rupture, like testicular torsion and other serious injuries to the *********, causes extreme pain, swelling in the *******, nausea, and vomiting. To fix the problem, surgery is necessary to repair the ruptured ********.
Old May 10, 2009 | 03:20 PM
CamperAndy's Avatar
The name of that web site caused me to spill my coffe in my lap. Now I have burned ones. Is there a web site for that?
Old May 10, 2009 | 04:47 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Tip:
Next Mother's Day buy Mom the flowers NOT the Fishing Rod.
Old May 10, 2009 | 05:13 PM
Dr. Evil's Avatar
That was good
Old May 10, 2009 | 08:29 PM
powermad's Avatar
Any swelling?
it doesnt seem to be swollen but there is a bruise and it hurts to apply pressure to my lower stomach. not really wanting to spend mothers day in the er i figure if it keeps up i will go though. i searched a bunch of websites but i wanted to know if it was normal for the pain to last more then a day
Old May 10, 2009 | 08:40 PM
Redleg's Avatar
Better get checked, risking a stricture (cut or tear) is the LAST thing you want to mess with.
Old May 10, 2009 | 09:05 PM
Riflemanusmc's Avatar
Registered user
LMAO Oh man, that brought tears....
Old May 10, 2009 | 09:43 PM
schamran's Avatar
I know I would SPARE NO EXPENSE!! They are just one of those things you can't buy back later!
Old May 10, 2009 | 10:50 PM
I would say get to the Dr. first thing tomorrow. Funny part is they may do an ultrasound on your sack! Hope the gel is warm and the tech is ugly
Old May 11, 2009 | 12:28 AM
powermad's Avatar
good news its just a nasty bruise! well not good news but better then the other news i could have had. i went to the er and the doc checked me out said i will be fine. i had a ultra sound done a while back and it was by a really hot blonde and the gel was warm and i said the pledge of allegiance about 600 times. thanks everyone for the help i really appriciate everything.
Old May 11, 2009 | 01:17 AM
madhat's Avatar
Better safe than sorry, brother. Glad you're ok.
