access a fuse ??
Old Jan 25, 2004 | 07:58 PM
dieselcrazy's Avatar
access a fuse ??
im thinking of using these for my aux. back up lights and also for when i install my cb. are they available in the mini fuse style ?? thats what my truck has in the side of the dash. any other suggestions ? thanks, scott
Old Jan 25, 2004 | 08:08 PM
BBWD's Avatar
Dieselcrazy:
Are you refering to "Add-A-Circuit??? These are manufactured by Littlefuse and the box has 2 part numbers; FHM200BP and OFHMO200ZP. I used them to hook up my gauge lights and other accessories. You can get them at Pep Boys. They work with the mini fuses in the dash. The box even comes with 4 extra fuses.
John (DH)
Old Jan 25, 2004 | 08:19 PM
john, is this what you are talking about ?? http://www.sportys.com/shoptool/images/1307l.jpg
Old Jan 25, 2004 | 08:27 PM
i was just looking at the access a fuse site. they said "Make sure that the extended terminal is on the Load side of the fuse panel and not on the Feed side of the fuse panel. Don’t be confused!" when you look in at your fuses and one side has an arrow , is that the feed side ?? thats what im assuming from a pic i found on their site ... scott
Old Jan 25, 2004 | 08:35 PM
BBWD's Avatar
Scott:
That is what they look like. On my 98 the hot side of the fuse is the top leg. You can check it with a volt/ohm meter.
John (DH)
Old Jan 26, 2004 | 05:03 PM
john:
i saw pep boys carries the add a circuit but it says to only use up to a 10amp fuse. is that enought to run aux back up lights ?? or how about a seperate add a circuit to power a cb ?? thanks, scott
Old Jan 26, 2004 | 10:24 PM
back to the top
bigjohn92
Nov 25, 2010 01:32 PM
Evildiesel
Nov 18, 2005 04:12 PM
tlea7
Mar 17, 2003 07:46 PM
Mexstan
15
Mar 17, 2003 03:22 PM
mymaur
Feb 24, 2003 07:08 PM
