5500 cfm elec fans
Old Apr 9, 2004 | 07:45 PM
04ctd's Avatar
5500 cfm elec fans
some one posted a OEM setup will pull 10k cfm, would this one work to keep the AC from being louder than the truck?
most aftermarket fans pull ~2200
http://www.northernautoparts.com/Pro...ProductId=1620
the ad:
These truck fans feature a one-piece glass-reinforced nylon shroud and two powerful motors with 15" blades! These rugged units are designed to fit full-size trucks with the large radiators (32" wide cores). The engine runs quieter, cooler and with higher horsepower, torque and mileage than with stock set-ups.
• One-piece molded glass reinforced nylon shroud with full contact rubber seal.
• Variable Speed Control: 60-100%
• Adjustable thermostat and A/C relay
• Quick, solid installation; minimal drilling
• Motor leads can be reversed to create a pusher fan, but efficiency is reduced.
• Recover 17-18 HP! by replacing the clutch fan with the dual electric fans.
• Boost torque by 20 ft-lb.!
• SAVE up to 2-3 MPG!
• 5,500 CFM air flow 17" x 31 7/8" x 4 1/2"
Old Apr 9, 2004 | 11:38 PM
BigBlue's Avatar
I'd mount one in place of the stock fan and one on the other side and you should have plenty of air flow.
lvmknsmoke..
Apr 9, 2009 03:47 PM
Wulfdiesel
22
Oct 21, 2007 06:19 PM
hotdram
30
Jun 26, 2003 04:35 PM
SolidJunkMM
Jun 21, 2003 08:09 AM
Demon_Customs
13
Dec 19, 2002 07:14 PM
