2001 Dodge Intrepid Codes
Old Aug 12, 2005 | 09:01 PM
cr1998's Avatar
I know this is a Dodge Diesel Truck forum, but I figured I could also get some input about a problem on a Dodge car as well. The Malfunction Indicator Light on my daughter's 2001 Intrepid is staying on and I am getting the following codes:
1684 The battery has been disconnected within the last 50 starts
0340 No camshaft signal being received by the computer
1391 Sometimes, I can't see the crank or cam sensor signal
The car seems to be running fine. Any recommendations from any of you regarding these codes I'm seeing?
Thanks,
CR
Old Aug 13, 2005 | 02:49 AM
Clunk's Avatar
P1391 Camshaft Or Crankshaft Position Sensor Intermittent Loss
It might be time to buy a cam position sensor or at least check the wiring connector and the sensor install for correct placement. Some sensors require a feeler guage to set the correct distance from the part to the sensor. I'd want a manual to get better info.
fade94
Oct 12, 2009 12:52 PM
mont
Jul 19, 2007 05:18 PM
capt.Ron
Jul 8, 2007 10:58 AM
jthorpe
Mar 4, 2004 04:10 PM
