1962 Caddy DeVille
Old Mar 31, 2004 | 10:38 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
1962 Caddy DeVille
OK guys, don't flog me too bad.
In the process of restoring daughter's '62 DeVille. Need to rebuild the water pump. Has anyone torn one down? The guts APPEAR to be standard GM. The impeller and fan mounting hub are pressed on. Not at all sure as to the procedure. I don't want to screw up the housing as they are hard to find for this model.
I need help, even if it of the non useful type I recieved from SOME members a week or so ago.
TIA
scratchingmyheadonthisoneShortround out
Old Mar 31, 2004 | 12:37 PM
JKE's Avatar
JKE
http://billee007.tripod.com/CadillacbyBond/id38.html
maybe check there.
Old Mar 31, 2004 | 03:18 PM
BigBlue's Avatar
That's a nice car. You got any pics of it?
Old Mar 31, 2004 | 08:51 PM
jaconst's Avatar
maybe you can get an aftermarket electric WP if problems become too many.
Just a thought?
Old Mar 31, 2004 | 10:35 PM
2manydogs's Avatar
The key is in re-assembly. Press it all apart, noting the position of the depth of the shaft into the impeller and pulley. Remember that when pressing the shaft into the bearing you MUST support the bearing so the shaft does not push it apart. I use a piece of tubing that just fits the OD of the shaft and is not too thick to mess up the bearing seal. It is a good idea to judge how much pressure it takes to get the pulley back on- sometimes they go back on with very little pressure- not good. Some of the old Continental engines have been done a few times and you could push the pulley on by hand. Have to have a sleeve put in the pulley for a tight fit. Hope this helps Jim
53 willys
Mar 17, 2008 11:09 AM
BEHRMAN
Jun 30, 2005 09:33 AM
jimk
Aug 30, 2004 02:25 AM
shortround
Oct 20, 2003 06:23 AM
Shovelhead
Jan 6, 2003 02:31 PM
