How Much Winch Do I Need?
I have a 2006 MegaCab 4X4 Diesel (of course) and would like to get a winch. I'm wondering how big of winch I need? I don't do any off-roading I would just be using it to get un-stuck about once every year or two, usually in snow. I have found a 3,000 lb winch for a very reasonable cost. I realize that it won't pull my truck up a cliff, but would it be enough to help me get out of the occasional snow drift? I can't see spending hundreds of dollars for something that I'll only use rarely. I also would like the winch to be portable so I can use it to pull items (snowmobile etc.) into my enclosed trailer if needed, so I would want something relatively light weight.
Thanks for the help in advance! [coffee] |
personaly i wouldn't go with anything smaller than 6K, prefeably when i get around to it I would like to get a 12K. warn has some reall cool ones that also have air compressors built in. as for potability for pulling sleds in i think that the little plug into the cig. lighter ones would have enought pull to do it.
I was kind of thinking along the 6,000 lb lines as well, but thought that I could always do a double line pull with the 3,000 to get 6,000 lbs straight line pull and usually that would be enough to get me out. Especially if I'm able to assist the winch with the tires turning?
I know that warne and others make some awesome winches, and if I were off-roading I'd probably spend the money for a bigger winch. But I can buy a new 3,000 lb. winch for $70! I also have a huge tow rope and a tow strap if I'm really stuck and have another vehicle around. But I was thinking that $70 is pretty cheap if it saves me some shoveling[yuk] |
I have a 2500 pound winch on my 700 some pound 4-wheeler...it pulls it out adequately...
If you get an 8000+lb. truck stuck, a 6000 pound winch is going to do nothing but go off on thermal overload, and probably drain your batteries in the process. A 3000 lb. winch would be like trying to put out a structure fire with a glass of water, IMHO. At the minimum, a 10,000lb winch... Personally, I'd get a 16.5K winch. They make portable winch's that you can use to pull vehicle's onto your trailer with. Just my .02.:) |
Originally Posted by megacabdad
(Post 2334546)
If you get an 8000+lb. truck stuck, a 6000 pound winch is going to do nothing but go off on thermal overload, and probably drain your batteries in the process. A 3000 lb. winch would be like trying to put out a structure fire with a glass of water, IMHO. At the minimum, a 10,000lb winch... Personally, I'd get a 16.5K winch. They make portable winch's that you can use to pull vehicle's onto your trailer with. Just my .02.:) A 10,000lb. Warne winch runs about $800-$1000. I'm just not able to spend that much. If winches were free or if I were loaded I'd have a 20,000 lb. winch. But, unfortunately, that is not the case...not in my world anyway. If the smaller winch will be worthless to me then I will just keep on going through life with no winch at all. I appreciate the input though. |
I used to have a 4500# winch on my Jeep Cherokee, its was barely able to pull it out of the snow when stuck. I used to use a snatch block when needed but that cut the usable length of cable in half which was around 30ft. Not very useful if the nearest winch point is 50ft away. It got replaced with a 9.5K warn winch. I use it on my tilt deck trailer now for pulling dead vehicles on.
I have a 2500# winch bolted to the floor of my garage for pulling dead vehicles into the garage. It barely pulls my 3500 dually in. I don't think a 3k winch will do much if you are stuck in a ditch, might be ok for just pulling thru a drift and not fighting uphill. Also you get what you pay for, I'm guessing a $70 winch will not take much abuse. How much cable is on it? Cann't really double line it if its got less than 50ft and still get any usable reach out of it. |
I would go ahead and get the 3,000 lb winch.
To load the trailer. :) I would look at something closer to the weight rating of the truck. Also when you figure weight, it increases dramatically depending on how "stuck" you are. |
Has anyone ever tried using a winch in conjunction with a tow strap or tow rope? I've often wondered how it would work to tighten the winch against the tow rope until the rope is streched and then try driving out? It would probably have to be tightened up more than once but it maybe it would get the truck moving. Usually if I can get the truck moving at all back-and-forth I will be able to work my way out.
get a real winch.... go with a pto winch[coffee][coffee] costs more but you will never run out of power[coffee]http://www.ramsey.com/winches/industrial.html
(Post 2334588)
You buy it for me, I'll gladly install it! OOps! I saw Warn.com and thought it was a winch. I know that I'll definately need a snatch block to make it work. |
Originally Posted by johnh
(Post 2334595)
get a real winch.... go with a pto winch[coffee][coffee] costs more but you will never run out of power....
(Post 2334595)
Originally Posted by tckitt13
(Post 2334579)
Also driving while winching can be VERY hard on a winch and even damage it if not done right. If you overrun the winch then slide back while spooling in you can take out the planetary gears from the shock load or even snap the cable. For this reason a winch's cable should not be used to tow someone out either. Just enough throttle should be applied to spin the tires and help the wincg out, not redline the engine and throw snow for 50feet. |
Yep, I knew this would happen. I've stated a couple of times already that price is a huge issue for me....but I guess I'll repeat it.
Price is an issue. I do not have the funds to purchase an $800 or more winch. The only reason that I'm considering any winch at all is because I found this one at a very reaonable price. But if it's not going to do me any good, I won't waste the money on this one either. Don't get me wrong, I appreciate the input. But I did not ask "what is the BEST winch for me?" I asked if this one would be any use or if it was useless to consider buying it. |
