winter build
winter build
well have been working on a new heart for my 05.head is having the intake cut off so it can be tricked from all angles.will have it fireringed.i have bought a new intake and intercooler from Joe Hellman.a matched set of springs and cam from Greg Houge.Greg also tucked a new set of high perfromance push tubes and a complete set of arp studs in the box.i have the crack rods so although it may be a mistake i will run them.if i dont destroy my current motor before i pull it out i will put new bearings rings and add TTS after market rods to it for a backup.as far as the bottom end things will be loosened up a bit.i told the engine builder do what he wanted,i plan to blow the pistons out of the block
.fuel will come from stage 3 II cp3 pumps with dual fuel rails. fuel will flow through big set of Wicked diesel injectors.i will still be running the multy stage nos launcher system and some new air will be coming but nothing has been finalized on it yet.should be on my shop floor by mid january...
Tedonlin150
46
Nov 21, 2011 10:45 AM
mrwaters
Dec 28, 2005 10:11 PM
