-   MDDTR #33 (https://www.dieseltruckresource.com/forums/mddtr-33-140/)
-   -   89 ctd starting problems (https://www.dieseltruckresource.com/forums/mddtr-33-140/89-ctd-starting-problems-234137/)
Exekiel69 Feb 23, 2009 02:56 PM
I'm in rockville MD and can't get My ctd to start after I removed the IP to re-seal it and put it right back.
Anyone near Me with timing tools or more knowledge than Me about how to start it?
Thank You.
lmills Feb 23, 2009 03:37 PM
Thank You.
did you pin/lock the pump at TDC before you removed it?
Exekiel69 Feb 23, 2009 05:14 PM
No, I used the same pump and didn't disturb the shaft. I just replaced a few seal's and put it back.
lmills Feb 23, 2009 06:14 PM
If you didn't turn the pump at all, then it should be OK. If the shaft was disturbed, it could be 180* out of timing. IN any case, they can be a major pain in the butt to prime. Where exactly are you in Rockville? I know the area pretty well.
Exekiel69 Feb 23, 2009 06:29 PM
I'm close to the intersection of Veirs Mill rd and Norbeck rd.
lmills Feb 23, 2009 06:43 PM
gotcha. :D Well, as mentioned, if the pump shaft was not disturbed it should have gone right back in since the shaft is keyed. The only other thing it could be is air. How long have you tried bleeding it? What process did you use?
scottsjeeprolet Feb 24, 2009 06:04 AM
Did you plug in the shut down solenoid when you were done?
Exekiel69 Feb 24, 2009 06:26 AM
I crancked it until fuel came out at all the injector lines, then cranked several times but it does not even puff smoke.
I removed the plunger at the solenoid to eliminate this option.
Exekiel69 Feb 24, 2009 10:30 AM
Does anyone have a picture or know how to align the marks on the cam and IP gear?
Thank You.
scottsjeeprolet Feb 24, 2009 11:10 AM
It's not that easy as just aligning up the marks. Looks like your timing will have to be reset. We have a timing set in the Cave that i don't know how to use, if you can get your truck up to Kingsville we might be able to help. But the Cave is only available to Chapter members. So it looks like you need to join!
Or you can call that shop in Glen Burnie and see if they do 12v timing.
Also you might want to start a thread over here
https://www.dieseltruckresource.com/...play.php?f=100
Might get more help
rollincoal02 Feb 24, 2009 11:35 AM
i wanna see the timing kit work on a ve pump LOL
scottsjeeprolet Feb 24, 2009 12:38 PM
Dang it i missed that one. [duhhh]
So go post your problem in the 12 Valve section. There are quiet a few VE pump experts in there.[coffee]
Exekiel69 Feb 24, 2009 12:49 PM
Thank You guys, the gurus have not shown up yet or the might be as stumped as I am. Thank You for the info.
94 12valve Feb 24, 2009 01:09 PM
we could stare at it for another 5 hours and see what happens
scottsjeeprolet Feb 24, 2009 02:08 PM
[eyecrazy] [deadhors]
That's funny! Good thing i got out of the way or it would have taken 10 hours![roll]
