Made my own 4" Downpipe
Old Feb 15, 2010 | 03:46 PM
TIMMY22's Avatar
A website sells 4" downpipes for $198 plus it was $52 to ship...>>>$250 Total.
I bought some fittings and a little time with my chopsaw and my mig welder, made up a 4" downpipe.
I cheated a little in that the cab is off the truck right now. So it was very easy to cut and tack pieces matching things up trimming and shaving with nothing in the way.
My main concern was making that first 90* turn off the turbo with enough clearance. I actually made the turn about 3/8" tighter on the outside closest to the firewall than the factory pipe.
This is a list of what I used...
4" OD to 3" OD reducer
4" OD OD 90* short radius (4" centerline) mandrel sweep
4" OD OD 90* long radius (6" centerline) mandrel sweep
4" OD OD 30* long radius mandrel sweep
$75 total
First, trim the clamp flange section off the original pipe. I cut it where the first visible ridge is where it expands a little (about 2" long).
Cut the 3" to 4" reducer as tight to the reducing section as possible on both sides. I was able to do this using less than 1" of run. Then cut one end of the 90* short radius as close to the turn as you can get. Leave the other side long.
The original clamp flange section fits nicely into the shortened reducer.
I then shaved one end of the long radius 90* on about a 10* angle. I kept matching it up till it looked good. This accounts for the little offset "jag" you need to be centered between the bell housing and the chassis. With a 10* angle on one end,the pieces matched up nice.
I then used the 30* elbow with a slice to drop down and get level again below the transmission crossmember.
I started welding it all up but my spool ran out of wire. I'll finish it in the morning.
Old Feb 15, 2010 | 04:02 PM
Nice!
Stuck...
Old Feb 15, 2010 | 04:37 PM
Nice work
We've needed this thread forever.
Old Feb 15, 2010 | 04:44 PM
Onemoparnut's Avatar
Nice work
Old Feb 15, 2010 | 04:57 PM
93Fury's Avatar
Looks awesome. Wish my cab was off when I did mine.
Old Feb 15, 2010 | 06:33 PM
NM1stgen's Avatar
Where did you buy the exhaust parts?
Old Feb 15, 2010 | 08:30 PM
TIMMY22's Avatar
I bought them from CarQuest auto parts, they did not stock 4" but I picked out the elbows I wanted from the catalog and they had them the next day.
Old Feb 15, 2010 | 08:57 PM
dieseldawg604's Avatar
nice job!!!
but whats that shiny black stuff all over your frame???
Old Feb 15, 2010 | 09:15 PM
rbrettctd's Avatar
I did the same thing, except instead of the reducer, i notched, bent, and welded the 4" pipe to the 3" flange... Looks good there.
Old Feb 15, 2010 | 09:21 PM
TIMMY22's Avatar
Originally Posted by dieseldawg604
nice job!!!
A new coat of paint, Body off chassis restoration.
Old Feb 15, 2010 | 09:22 PM
JustRamIt91's Avatar
Nice work, this is what i need to do!!!
Need to get a different flange though....did you use a flux-wire(what i have) or gas shielded mig? I'm thinking a gas-shielded would be better because of the extreme conditions.
Old Feb 15, 2010 | 09:36 PM
Alec's Avatar
Very nice, and yes, we have needed this post, with parts list, etc., forever!
Old Feb 15, 2010 | 09:49 PM
paint??
im gonna have to look into this!!!!
haha
looks great man!!
Old Feb 16, 2010 | 12:51 PM
Jungle's Avatar
Nice job!!!!!!!!
Old Feb 16, 2010 | 02:45 PM
i don't know how you use those flux-wire welders, they are the BIGGEST PITA ever. my friend has one i tried welding a drain plug into a trans pan and messed it all up because they're just so weird.
gas shielded mig FTW.
