Looking for VIN info want to buy asap
Old 05-20-2010, 04:02 PM
nitrous's Avatar
Hi guys I am back to the Dodge diesel world after a bad decision on buying a Ford. Let me say I am glad to be back
Iam looking at a 2005 Ram 3500 Laramie and wondering what gear ratio it has along with any warranty work that has been done to it. I would appreciate any info possible.
VIN
3D7LS38C25G820550
85,000 km not miles (in Canada)
Old 05-20-2010, 04:32 PM
cbrahs's Avatar
3.73 gears
no warranty left.
November 23, 2006 C3961 - PIONEER CHRYSLER JEEP
21950150 - Valve Body-Valve Body - Replace
08050198 - Alternator-Overrunning Clutch
325019 48,446 Kilometers 2006121 WARRANTY
November 1, 2006 C3961 - PIONEER CHRYSLER JEEP
18190420 - Module, Engine Control (ECM)-E
23510895 - Weatherstrip/Seal, secondary-d
324935 48,345 Kilometers 2006113 WARRANTY
October 10, 2006 C3916 - LANGLEY CHRYSLER
08508090 - Lamp, clearance-Lamps, Marker/
204066 47,597 Kilometers 2006103 WARRANTY
June 8, 2006 C9023 - OKANAGAN CHRYSLER JEEP
DODGE
18E17182 - Safety Recall No. E17 Out of P
S90908 41,550 Kilometers 2006062 RECALL REPAIR
DODGE
16500512 - Universal joints, single piece
A90908 41,550 Kilometers 2006062 WARRANTY
Old 05-20-2010, 04:34 PM
nitrous's Avatar
thanks cbrahs....does any of this info alarm you ?
Old 05-20-2010, 04:35 PM
cbrahs's Avatar
1 open recall. H46-steering linkage
if the previous owner did not do the steering upgrade, then dont worry about the recall. it will not apply to your truck
Old 05-20-2010, 04:36 PM
cbrahs's Avatar
none of this would scare me off from buying the truck. ask the dealer (if you are buying it from a dealer or the original owner) if they have any service records for the truck.
Old 05-20-2010, 04:37 PM
cbrahs's Avatar
looking at it, all of the warranties expired on May 12th of this year.
Old 05-20-2010, 04:41 PM
cbrahs's Avatar
dug a little deeper. The may 19th with a differential case would be a curious question to ask. why they had to replace the front diff housing. maybe it was bent from the factory or gears came apart. don't know. might ask about that.
May 19, 2006 C9023 - OKANAGAN CHRYSLER JEEP
DODGE 02401501 - Case, differential-9.25 axle
A90447 40,178 Kilometers 2006073 WARRANTY
DODGE
02121001 - Seal, drive pinion oil
19630101 - Tie rod end-To pitman arm
A90407 40,178 Kilometers 2006055 WARRANTY
May 16, 2006 C9023 - OKANAGAN CHRYSLER JEEP
DODGE
16300103 - Propeller shaft, w / universal
A90297 39,920 Kilometers 2006054 WARRANTY
November 4, 2005 C9023 - OKANAGAN CHRYSLER JEEP
DODGE
19203602 - Shroud, steering column-Fixed-
A85300 19,229 Kilometers 2005112 WARRANTY
April 8, 2005 C3916 - LANGLEY CHRYSLER
85900040 - Road Ready Prep-Basic Prep
K80322 3 Kilometers 2005042 PREPARATION
Old 05-20-2010, 04:42 PM
nitrous's Avatar
also is the valve body for the tranny ?? never heard of that issue before
Old 05-20-2010, 04:45 PM
nitrous's Avatar
its a private sale he is second owner and not aware of any previous service records or issues, and yes differential case that is strange
Old 05-20-2010, 05:00 PM
cbrahs's Avatar
That may have been changed for the typical shuttle shift. the dealer may not have had the solenoids in stock or an attacthment point was messed up and they replaced the entire valve body. I would not worry about the valve body replacement.
Old 05-21-2010, 03:34 PM
nitrous's Avatar
Thanks again cbrahs. Prob going to pull the trigger on this. For a 05 it looks in very good shape and with only 83000 km approx 55000 miles I cant ask for any better. Boy these 5.9 sure hold there value up here in Canada !!!
Old 05-21-2010, 03:36 PM
cbrahs's Avatar
you are welcome brother. anytime. post pics of the ol girl when you git r
Old 05-22-2010, 03:40 PM
snowmanx's Avatar
Don't buy it, get a duramax.
Old 05-25-2010, 08:45 AM
nitrous's Avatar
A Duramax wow you must be bright. Obviously you are a little jealous of the Cummins aren't you, otherwise you would not waste your time on this site. I sure don't find myself ever on a duramax forum.
If I wanted a duracrap I would get one. I have owned all three Dodge, GM, Ford, and I take pride in the Dodge Cummins and would never own anything else
cbrahs
02-10-2014 07:54 AM
Bowser50
07-26-2009 07:22 AM
kpracing
07-10-2006 09:48 PM
I PASS GAS
01-25-2006 07:51 PM
Quick Reply: Looking for VIN info want to buy asap
