Home Made Steering Brace
Old Oct 3, 2010 | 12:52 AM
spence78's Avatar
After reading on this site and numerous others about the steering braces, I decided I would make one. As paying $250 for one seemed a little steep. the construction was pretty straight forward. I used some 4" angle and some 2" 1/8 tubing and 1/4" plate. The total cost was about $40-$45 dollars as the bearing cost $30. The shaft is 7/8" draw link pin for a tractor which has a thread that is the same size and pitch as the steering box as well as is grade 8 I believe. The last pic is of it just tacked together as I built it on the truck and then ground and trimmed it to finish it.
http://sphotos.ak.fbcdn.net/hphotos-..._2801576_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._2918624_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._7936032_n.jpg http://sphotos.ak.fbcdn.net/hphotos-..._4142344_n.jpg
Old Oct 3, 2010 | 04:46 AM
prattman's Avatar
Nice job. That came out real nice. -Glen
Old Oct 3, 2010 | 07:20 AM
89dieselkong's Avatar
Wow that came out real nice, wish I could weld!
Old Oct 3, 2010 | 03:12 PM
Zeppe807's Avatar
That turned out great! Where did you find that pin? I have been looking for one locally, but cannot find one.
Old Oct 3, 2010 | 03:56 PM
Catmandoram's Avatar
GREAT JOB. I'm going to try to make one. any pointers?
Old Oct 3, 2010 | 04:22 PM
Blake Clark's Avatar
Excellent Job!
Old Oct 3, 2010 | 06:01 PM
NavyDood's Avatar
Is this supposed to be preventive to keep the death wobble away or something?
Old Oct 3, 2010 | 07:06 PM
It's part of the sulution. When you run big tires... things tend to move alittle.
Old Oct 5, 2010 | 02:06 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
Very nice! I'm going to have to do that now! Any idea where the pin could be ordered? I have never seen that at the local tractor and farm stores.
Old Oct 5, 2010 | 06:13 PM
spence78's Avatar
A bit more info
Thanks guys. As for the pin I got two 7/8 UNF(fine thread) nuts and thread the pin in and then welded them together. Once welded together I could decide where to cut it and then I threaded it back in and welded it up. The pin came with one regular nut and one jam nut as well as a lock washer, but I had already bought some from fastener store.
Here is a link for the pin. It's a 7/8" category 1 lift arm pin.
Now as for pointers to anyone who wants to make one I think just making it on the truck worked pretty good as you can bolt on the end/side brackets to the anti-sway bar location the cut the cross member piece and then get a measurement on the bearing holder piece. What I did was drilled out the bearing holder piece and mounted the bearing and pin and once, I saw it was flush I tacked it. I ting to be careful of when un bolting the sway bar is that if your not parked on a even surface there might be stored tension, and it could hurt you if not that the bar weighs a freakin' ton and it could swing down and hurt, you so use a jack stand.
Here is a link on how to install
if the links don't work just goggle 7/8" category 1 lift arm pins and the article on the install is from dieselpowermag.com
Old Oct 5, 2010 | 09:10 PM
Now I see... thanks!
I didn't realize the pin didn't come that way. The tractor store has the pins with the male thread there. What is a good source for the bearing?
Old Oct 6, 2010 | 10:29 PM
spence78's Avatar
I bought my bearing at an industrial supply place, but I could have payed about 1/3 the price from a place called princess auto. They sell a 4 bolt flange one that would work for about $10-$11 Their website is www.princessauto.com
Old Oct 7, 2010 | 08:20 AM
excellent! thanks
Old Dec 12, 2010 | 10:37 PM
goran_volvo's Avatar
farm and fleet has the pin and 4 hole bearing housing and bearing , but problem with 4 hole bearing housing is the size , so best beat is to get 2 hole bearing housing , on eBay you can get one for 15 $ shipped
And my total cost was 15 $ for bearing and bearing housing, 2.99 $ for pin with lock washer and nut, 10 $ for all metal from scrap metal place
So total is 27.99 $ + plus my tame cutting and welding
Old Dec 13, 2010 | 12:36 AM
Zeppe807's Avatar
My story is similar; $3 for pin, $25 for bearing, scrap for free outside my door.
Worked great!
Thanks,
Joe
