White smoke
Old Oct 31, 2006 | 01:05 PM
eliminate this's Avatar
Unhappy White smoke
When I get off the throttle,I am getting alot of white smoke out of the exh. Help.....
Old Oct 31, 2006 | 05:03 PM
West Coast's Avatar
smoke
Is it pure white? Or black with white haze?
Have you checked your oil for water/anti freeze?
Is there oil in you radiator?
Old Oct 31, 2006 | 05:08 PM
B.Law's Avatar
This has happend to me twice, and both instances has been injectors.
The first it would bellow pure white smoke under acceleration.
Second instance it would produce a decent amount of white/greyish smoke at idle.
Old Oct 31, 2006 | 06:33 PM
No water in the oil or oil in the water.
How do I check to see if it is an injector....
Thks Guys
Old Oct 31, 2006 | 07:20 PM
West Coast's Avatar
Crack one injector line at the head, one at a time while truck is running. If motor idles down that is normal. If it does not change the idle it could be a bad injector in that hole.
Old Oct 31, 2006 | 07:34 PM
Timmay2's Avatar
what does the smoke smell like?
most the time white smoke is coolant..
Old Oct 31, 2006 | 07:53 PM
inline6power's Avatar
sometimes, not most of the time. i had a fuel leak on my truck and over night when it would lose fuel prime, it would smoke white while i was crankin it till it started. after that initial start, everything was fine.
Old Oct 31, 2006 | 10:12 PM
B.Law's Avatar
This doesn't apply to HPCR Cummins right? Cracking the lines on a running 3rd gen seems like a BAD idea.
Old Nov 1, 2006 | 07:04 AM
plow's Avatar
If you haven't changed the air filter lately try that, a stopped up air filter will make it smoke white.
Old Nov 1, 2006 | 09:27 AM
1-2-3's Avatar
Just a plain ole guy
What would you do then unplug the injector?
Old Nov 1, 2006 | 09:36 AM
AlpineRAM's Avatar
I'd go to the dealer and let him do a cylinder cutout test with the drb tool.
Old Nov 1, 2006 | 01:49 PM
flashgordon's Avatar
I agree bad bad idea on a 03 or newer!
Old Nov 1, 2006 | 02:14 PM
Thanks for the replys I will take it in for a cut out test...
I am getting a P 0016 code "error has been deteted for cam shaft out of phase with crank shaft" Is this a sensor or do I have to adjust the timing?
Old Nov 1, 2006 | 09:15 PM
Ok....Now im getting the
P 2509 "ecm/pcm power input signal intermintent"
P 0148 "fueling error" go to pinpoint test at.
So what does all that mean lol...
Old Nov 2, 2006 | 02:33 AM
AlpineRAM's Avatar
Sounds like a ground problem or connector problem to me- but I'm no expert on the CR Cummins. Did you do the tone wheel mod?
AlpineRAM
