What's inside my tank
Old Oct 9, 2006 | 10:41 AM
shand101's Avatar
I had a recent lift pump failure and replaced it about one month ago. My truck died on the freway just yesterday and I had it towed again. on investigation I find that the lift pump is sucking air. I have 3/16 of a tank of ruel showing on the guage and by my experience with this truck it should be correct.
My question is: what is inside the tank? Is there a pick-up tube that could fall off or something else that could make the suction point be above the fuel level.....or has anybody had a fuel guage go south suddenly, with out warning.
Is it a big job to drop the tank?
Old Oct 9, 2006 | 11:25 AM
rockwithjason's Avatar
depending on the year, some models have steel pick ups that rust out and allow air to get in.
Old Oct 9, 2006 | 01:16 PM
shand101's Avatar
Thanks Rock,
Got tired waiting for help so I dropped the tank. No metal, all plastic. Tank was empty. The gauge was reading wrong. I have the sending unit out and moving by hand it wouldn't drop below 3/16 level on the gauge. couldn't see anything physically wrong so I disconnedted it and turned on the key. The gauge went to 3/16 and slowely dropped to empty. I plugged the sending unit back in and now it works fine......Go figger!
By the way...dropping the tank is simple enough , but getting the electrical plug and quick disconnect hoses off is a *****. Easy to screw something up if you are not careful and let the weight of the tank hang on the connectors and hoses
TJE
Oct 25, 2006 10:21 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
2500CTD
Feb 27, 2005 01:29 AM
