Water in fuel light ?
Old May 29, 2008 | 10:57 AM
larry1951's Avatar
Washed my 1991 Dodge Cummins engine at the car wash yesterday
and now the "water in Fuel light" is on. Had a full tank of fuel and
had the alternator and relays covered up during the pressure washing.
I left the hood up in the sun for a while and the light went out and stayed out for the rest of the day yesterday. Sounds like a wet electrical connection
but where do I look ? Fuel filters are new.
Old May 29, 2008 | 11:11 AM
cm979's Avatar
Had the same problem. Look at the bottom of your filter bowl where the water sensor plug goes. Unplug it, 10 to 1 chance thats your problem, blow it out with an air compressor or dry it the way you prefer. I took and put grease around the seal when I put it back in, have not had the problem since. Hope that helps.
Old May 29, 2008 | 02:56 PM
1-2-3's Avatar
Just a plain ole guy
Use dielectric grease. Comes in a small spray can. Made to keep electrical connections clean and dry.
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
acker1
Jun 30, 2003 03:13 AM
