washer fluid reservoir
Old Dec 18, 2007 | 08:38 AM
Invader's Avatar
No matter how hard I pull, or push from the bottom, that ******** doesn't want to lift out. I see the 2 indents, but can't put enough pressure on those and lift at the same time. Be there any tricks?
Old Dec 18, 2007 | 10:23 AM
1-2-3's Avatar
Just a plain ole guy
yes there is. I've had to take mine out too. You have to pull it back away from the mounts. It's just some plastic tabs that slide into a slot then kinda lock in. You can also slip a large screwdriver between the bottle and the plastic it snaps into.
Once you dig it out you'll see how the tabs work.
PM me and i'll send you a pick that might help.
Old Dec 18, 2007 | 11:15 AM
Invader's Avatar
The screwdriver trick worked
Muchos Gracias.
Now.. for a radiator that isn't bent along its long axis...
/sigh.. waiting again.
btw, I was || close to cutting it out..
Old Dec 27, 2007 | 04:24 AM
catnfool's Avatar
thanks for bringing this up- mine leaks about half way down, and I have made two half-hearted efforts to get it out, then stopped before I got the sawzall out...
SOhappy
Mar 28, 2013 08:13 PM
Haney
Nov 1, 2012 07:05 PM
Vinceg99
21
Feb 11, 2007 10:06 PM
Dave88LX
Jul 2, 2005 09:53 AM
