Vibration at different points
Old Sep 8, 2007 | 07:50 PM
latman's Avatar
I'm getting ready to move and have to tow a trailer about 300 miles and I have noticed that I now have a vibration that seems to be getting worse and worse. I get the vibration at a constant speed of about 60 mph and then also some times when I'm slowing down not with the brakes but idling down at a slow speed. I have checked the U joints and I haven't found anything obvious with them one of the rear ones does have a little grease coming out but nothing else seems to be wrong. I've checked the bolts on the u joints and they are all tight and I'm just a little clueless as to what the problem could be. Anyone have any ideas? I have 48000 miles on it and its an 04 Quad cab 4X4 2500 and pretty much all stock. PLEASE HELP>>>>
Old Sep 9, 2007 | 11:45 AM
Clunk's Avatar
When you check u-joints, you have take the drive shaft out to be sure there is a full range of smooth motion in all directions. Not doing so can hide a slight binding in one joint like on 'ol Rastus when I missed one.
Old Sep 9, 2007 | 04:28 PM
Busboy's Avatar
Like a friend of mine says........ "why change them now? It's much easier to change them at the side of the road"
Old Sep 9, 2007 | 07:16 PM
gooseman495's Avatar
My buddy had 04 doing the same thing. When I grabbed the drive shaft it seemed OK . But when I pulled out the driveshaft I found the joints binding. Replaced u-joints & problem was solved.
jhenson
Sep 8, 2012 10:37 PM
Fisherguy
29
Aug 6, 2009 12:45 PM
LovinTheTorque
16
Jul 24, 2007 10:21 AM
Dave88LX
Dec 8, 2006 02:53 PM
andyr354
Aug 15, 2006 11:05 AM
