uncontrollable front wheel shimmy
Old Mar 14, 2007 | 12:35 AM
TheBigNasty's Avatar
If you are looking at the bottom control arm mount you will see a bolt with an eccentric cam on one side. What you do is loosen the nut, and twist the bolt to the next notch on it. It will push the bottom of the axle forward, moving the bolt backwards in the hole (towards the rear of the truck). Do this to both sides and it should help. If you still are drawing ????'s in your mind I can take some pics tomarrow to help describe.
Old Mar 14, 2007 | 07:37 AM
danimal 95's Avatar
no i understand just wasnt sure how to accomplish it on that style front end,youve been a ton of help thanks again
Old Mar 14, 2007 | 03:03 PM
johnny5.9's Avatar
I don't mean to hijack the thread but I am having the exact same problem with a 91.5 W250. Besides the balljoints in the steering and tierod should I check the kingpin bushings since it has no balljoints there? I am not sure if the kingpin bushings wear out like that or would cause the problem. I grease everything frequently but I don't know about the PO. The truck had new shocks last year. Could it also be my serviceable bearings in the fixed spindle?
Old Mar 14, 2007 | 06:35 PM
Rampage1967's Avatar
The kingpin bushings on that 91.5 can be bad enough to cause that without showing in tests. Take the bushings out & physically inspect them if you cannot find anything loose in the front end. That's what I had to do to fix the death wobble on mine. It hasn't shook since.
Old Mar 14, 2007 | 11:17 PM
johnny5.9's Avatar
Thanks alot for the help Rampage.
Old Mar 15, 2007 | 08:01 AM
You're welcome, did ya find the source of the shake??
rkleypas
Sep 7, 2013 07:42 PM
DNRCustoms
Jan 9, 2011 07:35 AM
GFB
Jun 16, 2007 08:23 AM
93' Shorty
Nov 22, 2004 03:05 PM
Junk Yard Dog
Mar 15, 2004 11:47 AM
