U joint replacement
Old May 9, 2007 | 06:01 PM
Treangen's Avatar
U joint replacement
Anyone have a trick for removing the inner clip from the u-joints in the front before using a ball joint press to get them out?? Working and working and can't get them. HELP????
Old May 9, 2007 | 06:09 PM
ClackClack's Avatar
Bigger hammer and a good drift is what I used... not sure if this is preferred, but it worked!
Old May 9, 2007 | 08:20 PM
LJRoy's Avatar
I didn't have any problem with these - just used a medium-small flat blade screwdriver and a hammer. One good sharp tap on one of the clip ends and they backed off enough to then pry them out.
Old May 9, 2007 | 08:22 PM
Black SunShine 04's Avatar
What a sign that your U joints are going bad?
Old May 9, 2007 | 09:41 PM
XLR8R's Avatar
Normally you can hear them - the sound changes with vehicle speed, although it's common to only hear it at take-off or at highway speed as a vibration.
Old May 9, 2007 | 10:58 PM
2500Ram's Avatar
And needle nose pliers. No problems with mine. Pressing them out is another story but a cheap 3 ton Harbor Freight shop press for $80 fixed that up as well.
Good luck.
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
zookeeper
Apr 5, 2004 05:33 PM
