Tranny making weird noise
Old Apr 22, 2008 | 12:13 AM
AmadosWorker's Avatar
when my truck is off and keys in accessory position (wait to start light) I can hear a motor running (sounds like a fuel pump) from the tranny pan. While this motor is running i hear an inconsistent tapping noise almost like fluid dropping to the bottom of the pan.After 20 sec, the motor stops running, the sound stops then it starts all over again. I cant hear this noise when truck is running. Truck drives fine.
Maybe this sound is not coming from the tranny i have been reading and it sounds like maybe a lift pump?
Old Apr 22, 2008 | 07:14 PM
GAmes's Avatar
That would be a no on the lift pump. Our 12 valves are mechanical, so they don't run if the engine isn't running. I'm thinking the heater fan. Do you know where it is?
Old Apr 23, 2008 | 01:42 AM
Where is the heater fan located? I have not had my truck very long so im uneducated about it.
my bad was thinking i had an electric lift pump.
My buddy was saying that it could be the heater grid relay clicking. Its hard to locate the sound but im pretty sure now that its not coming from the tranny
Does it make a difference if I dont hear the sound when the truck has sat over night? Only after it has warmed up
Old Apr 23, 2008 | 08:12 AM
GAmes's Avatar
It's on the passenger side, pointing down at bottom of the plenum. 3 small bolts and a wire connector to remove it. It may have leaves or other debris inside the cage that you hear rattling.
If they are working properly the heater grid relays don't click on and off, especially if the engine is warm. You would see a corresponding rise and fall on your voltmeter if they are the culprit.
beavertail
Jun 2, 2011 12:04 PM
Camarokid77
Jun 16, 2010 05:40 AM
Common
Apr 9, 2008 10:25 PM
Beeram305
Nov 19, 2005 01:56 PM
Huey
Oct 14, 2003 12:34 PM
