torque converter
Old Nov 2, 2003 | 06:26 PM
torq's Avatar
torque converter
Hey , My torque converter doesn't seem to be locking up my accelaration is much slower than before and i can't seem to figure out if it could be an electrical problem or just a bad TC. i have a 2000 24v 4x4 . i appreciate any help. :-[
Old Nov 2, 2003 | 06:32 PM
torquefan's Avatar
Re:torque converter
Try lifting up on your brake pedal with your foot while cruising at lockup conditions. Might be bad switch adjustment.
Old Nov 2, 2003 | 07:55 PM
tmiller24's Avatar
Re:torque converter
Lean toward the electrical problem, doubt it is the converter. Throttle position sensor, or APPS on the 24V, could also be acting up.
Old Nov 3, 2003 | 09:08 PM
torq's Avatar
Re:torque converter
i tried the tpps reset already that didn't help. but last night i unpluged the electrical connections and tried to clean them on the tranny and computer and now it seems to work right some of the time. Like i'll slow down and when i acell it feels like it's soppose to but the next time it wont so i think there must still be a dirty connection.
Old Nov 6, 2003 | 03:02 AM
AlpineRAM's Avatar
Re:torque converter
Try to clean the battery posts. The battery is the biggest noise filter in a car or truck, proper contacts are necessary to avoid problems.
HTH
AlpineRAM
Old Dec 16, 2003 | 09:51 PM
bama's Avatar
Re:torque converter
clean battery posts,possibly clean apps,reset apps, if that kinda helps ,a noise filter may be the ticket.also try running an additional ground to your pcm housing...this worked for mine.
Old Dec 25, 2003 | 07:33 PM
olivmatt's Avatar
noise filter probably won't help. you can rewire the tps and solve the lockup issue though. let me know if you need help.
scott
gpcinc@yahoo.com
lniemeyer2
Oct 24, 2012 12:11 PM
93dieselZak
Jun 16, 2011 06:10 PM
mainer
Jul 17, 2007 07:13 PM
