Tac Stopped Working ???
Old Oct 28, 2005 | 02:45 PM
strokethis3500's Avatar
My tack dropped to 0 and started smoking and backfiring for about 10 mins then tack jumped back up and stopped smoking ran fine for a few miles then started again.. any help would be great thanks
Old Oct 28, 2005 | 02:59 PM
crobtex's Avatar
Probably connected to your other post.
Have you changed the fuel filter lately? Do you know if your lift pump is working?
Old Oct 28, 2005 | 03:04 PM
BRD's Avatar
BRD
check for code p0341 camshaft position sensor, mine went out at 53k
Old Oct 28, 2005 | 04:15 PM
amartinson's Avatar
So did mine. But on a 1999, I believe they used a CRANKshaft position sensor. I agree that this is probably your problem though.
Old Oct 28, 2005 | 04:49 PM
its got a code p0336 ckp?
Old Oct 28, 2005 | 05:28 PM
crobtex's Avatar
P0336 Crankshaft Position Sensor Performance.
You can find it here: http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
Old Oct 28, 2005 | 06:05 PM
RATTLINRAM's Avatar
I had to replace mine, but I was lucky because the Check Engine Light came on and I had the code read by a buddy with a scanner. It took about an hour after finding the correct tools. The starter bolts can be a BEAR to break loose, but it was an easy job.
CLICK HERE FOR SOME GOOD INFO ON THE CRANKSHAFT POSITION SENSOR
Mike T.
May 2, 2008 11:07 PM
Towrig
Aug 27, 2006 11:40 AM
jcb
Nov 27, 2005 05:45 PM
strokethis3500
Nov 3, 2005 09:44 AM
hippie
Sep 12, 2003 10:33 PM
