sudden power steering loss
Old Feb 16, 2007 | 07:13 AM
themacfive's Avatar
My husband's 2000 Dodge Ram suddenly lost all power steering...when checking the fluid level, he noticed it full...but appears to be leaking...any thoughts?
Old Feb 16, 2007 | 07:27 AM
Joe Mc's Avatar
Bad pump or drive between vac pump and steering pump failed? Possibly the steering box has an internal leak not allowing the pressure to assist and work it's magic? That could be a place to start?
Old Feb 18, 2007 | 07:38 PM
njforestfire's Avatar
I went thru the same thing and lived with it for a while until I hit a pole on a bend...that sucked. After body repaired and replaced... 3 power steering pumps, 1 steering box and 1 stabilizer later it seems to be working ok. It started with the stabilizer being 'flattened' which over-worked the steering box over time which totally screwed up the pump. Replaced the lines first (very inexpensive) for I was informed that some of the lines collapse over time - the rubber lining breaks down and can clog the pump. Might be a good place to start for ya.
You say leaking...from where?
doug60
Nov 12, 2005 05:43 AM
gdukes
May 31, 2005 06:56 PM
turbo-nr
Jan 19, 2005 08:50 AM
jasonlb
Jan 15, 2005 11:11 AM
gdukes
Jul 15, 2003 09:45 PM
