Stuck throttle problem
Old Feb 6, 2009 | 07:59 AM
DeerHunter812's Avatar
On my way to school last night my pedal stuck to the floor and I couldn't get my truck stopped. When I pull the whole throttle assembly back by hand with the vehicle off to full throttle position it sticks like there is no spring tension pulling it back to idle position. This problem is on a 1994 12v diesel with p7100 injection pump.
Thanks in advance,
Old Feb 6, 2009 | 11:36 PM
patpat paul's Avatar
re stuck throttle
i had this problem and turned out to be a loose linkage on my 98 12v the linkage has a bend up and a bend doun it is under fuel shutoff my jam nuts on it came loose!
Old Feb 7, 2009 | 10:15 AM
infidel's Avatar
Maybe the return springs fell off.
There are two, one inside the other, that run between the power steering pump and the linkage.
Generic springs from an autoparts or hardware store will work.
birdboy
Dec 12, 2018 09:02 PM
Baja
Jan 29, 2008 08:17 PM
04ctd
Sep 14, 2004 04:43 PM
christinyou
Feb 7, 2003 09:32 AM
