Stuck with 150 Miles to go!
Old May 30, 2008 | 11:54 PM
BuildingBoost's Avatar
I am stuck in Pocatello, ID on my way back to SLC! The fuse on my wire harness for my FASS Blew. I changed the fuse and it blew again. The truck runs, but can I make it back to SLC? What are the risks running the truck another 150 miles without the FASS running?
Thanks in advanced!
06 Mega Cab
II 3 flow Injectors
Silver Bullet
Bully Dog
TST R49
Old May 31, 2008 | 12:02 AM
Alwaysworking's Avatar
alwaysonDTR
if it keeps blowing the fuse,then i would guess there is a short in the wire some where.
Old May 31, 2008 | 12:08 AM
oldblues's Avatar
hi
can you get a piece of wire and run a temp hook up to get you home ?
Old May 31, 2008 | 12:19 AM
If I can't get it working, can I still drive the 150 mile without it? What are the risks?
Old May 31, 2008 | 06:35 AM
donhov's Avatar
To me the major concern is .....is the pump or the in tank if it is still there supplying enough fuel to not damage the CP3. Do you have the option to purchase a cheap pump to mount temp just to get you home? And as above can you run a temporary wire and maybe not blow a fuse with it?
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
Baja
Jan 29, 2008 08:17 PM
heavyJ
Oct 25, 2007 09:08 AM
Ramtuff06
Aug 21, 2007 06:21 AM
