spedometer problems
Old Nov 3, 2004 | 07:04 PM
doodah's Avatar
spedometer problems
Well, my speedometer has been acting funny for a couple weeks now, When you first get going down the road, it will climb up to 55 and stop. nomatter where I go or how fast, it will only climb up to 55 it will climb up there faster then I think it really is too. it takes about 5-10 minutes then it just kicks in! and it works fine the reast of the day! and this morning it was 20 degrees out and it didnt even work at all! works fine now tonight coming home! it seems like a temp thing, but I am also 5 mph faster then what it says so 60 is 55 because I did not get my needle exactly back in same place after putting my white faces on, is this a temp problem or could my white faces be lifting enough to stop the needle from moving in a certain spot. your suggestions is required
Old Nov 5, 2004 | 09:44 AM
signature600's Avatar
AH! You pushed the needles on too far, now they stick!
I did the same thing with mine. All you need to do, is take them back off, and put them back on, but not so far.
Pretty Easy
Let us know if this works or not, and get some pics of those things in your gallery, I want to see if I made the right choice going with Silver faced or not
Chris
Old Nov 5, 2004 | 06:36 PM
doodah's Avatar
That thought has cr4ossed my mind too!, I will try it tommarow! thanks for the words of incuragment! I will try to get some pix too!
Jschlachta
Aug 21, 2008 04:58 AM
Thedieselkid
Mar 8, 2008 11:18 AM
donald.emmack
Mar 18, 2007 10:55 PM
dodge250
Sep 25, 2006 06:08 AM
