Problem installing my Mag-Hytec front Dana 60 cover....
Old Aug 17, 2003 | 04:00 PM
Commatoze's Avatar
I started out today to install my front differential cover, but quickly ran into trouble. I lost the installation instruction sheet which noted what linkage components to remove and where to remove them in order to get the new cover on. So I decided I was going remove the tie rod from the drag link and then swing it slightly out of the way to slip the new, larger cover behind it. Try as I might, even with the help of a "persuader", I couldn't budge the stud of the tie rod from the drag link. I could have wailed on that stud all day, and it wasn't going to pop free. Am I going about this the right way? Do I need a puller? Maybe I should remove the tie rod end from the driver's side wheel and then swing it out of the way. Anybody done this install that can lend a suggestion?
Old Aug 17, 2003 | 04:54 PM
AKDSLDOG's Avatar
Re:Problem installing my Mag-Hytec front Dana 60 cover....
Just a "pickle fork" and a large hammer, should do the trick. If not try loosening the nut till it just sticks above the threads and wail on it with a hammer! But be carefull not to damage the threads. Other than that I have had to use a torch on a couple at work. >
Old Aug 17, 2003 | 07:42 PM
tlea7's Avatar
Hi Tom,
I wouldn't pound on the stud even with a nut on it. If you don't have a pickle fork whack on the side of the socket a couple of times with a 3-5 # hammer. This will distort the sleeve just enough to pop the stud out. I've done this for years even when I had a pickle fork in the drawer. Good luck!
Tim
Old Aug 17, 2003 | 07:52 PM
Commatoze's Avatar
Thanks for the info guys. I don't have pickle forks, and that's why I went to work on the tied rod/drag link joint instead of the tie rod ends. The service manual says to use a tool whose picture kind of looks like a gear puller in reverse. It clamps behind the socket while the screw stud pushes against the ball stud. I've tried knocking...ok pounding on the stud (too late Tim ) but that didn't work either. I'll try striking the sides of the sleeve, and pick up a pickle fork this week. Thanks.
Tom
Old Aug 18, 2003 | 08:54 AM
duner's Avatar
autozone loans them out for free but i'm assuming everyone already knows that
lsgibb
Jul 14, 2006 07:43 AM
6 Shaker
Jun 18, 2006 01:42 PM
Commatoze
0
Oct 15, 2003 12:33 PM
Commatoze
Apr 2, 2003 12:53 PM
