Problem codes
Old Aug 17, 2007 | 04:31 PM
grippo's Avatar
Problem codes
If I have the P0628 problem code showing...Fuel pump relay circuit low/ Fuel lift pump circuit low, does that mean the problem is electrical or the problem is the lift pump itself? Because it definitely seems like its the pump.
Old Aug 17, 2007 | 04:37 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
If there is a problem with the curcuit or the relay, that will have a direct effect on the performance of the lift pump. I'd start by checking for bad wires and connections and checking out the relay. If all that looks good, you just might have a bad lift pump on your hands...
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
