Panel/defrost/floor
Has anyone worked on there motor controls for there Panel?
Mine quite adjusting and is always coming out of panel nomatter where I put control. I started taking it apart too fix and let me tell you there must be 100 screws holding dash together, problem is there is a reinforment brace behind dash looks like I need too take this off also? Has anyone done this before? If so help Please. 03 58000 warranty out 36000. Andy |
Before taking anything else apart, check for any vacuum leaks under the dash or under the hood (along the firewall). It may be that a vacuum line is leaking. I have accidently knocked a line loose when messing with something under the hood. You might get lucky and find that to be the problem. :D Sure would beat having to tear the dash apart.
Panel/defrost/floor
I did find that motor for panel is working.
But plastic gear that motor connects to just will spin buy hand. Almost as there isn't anything connected too other side? Andy |
