overdrive mishap, please respond imeidatly!!
Old Jan 4, 2003 | 10:39 AM
doodah's Avatar
sorry about the spelling, but i was in my truck putting another switch in the dash, right next to overdrive button, had to take the switch out of over drive spot and i accidently grounded out the wire,,, is there a fuse that i am missing while checking them or what?? i looked at the fuses and thought i checked them all but could have missed one.. please help!!! ???
Old Jan 4, 2003 | 12:23 PM
pwabbott's Avatar
Re:overdrive mishap, please respond imeidatly!!
doodah,<br><br>The overdrive switch is not fused according to wiring diagram, One lead goes to the Powertrain Control Module, The other lead goes to Transmission Control Module. Both of these are micro electronic devices. Did a hot wire come in contact with one of these leads?<br><br>Have you driven the truck since then? Is shifting OK or are you missing overdrive now?
Old Jan 4, 2003 | 01:29 PM
doodah's Avatar
i took the truck out and it shifts fine and the switch works fine.. it is just the light in the button does not come on with it off.. what happened was i had the switch off the plug in and i happened to have a ground wire come into contact with a hot wire on the conector, so the button wasnt even on the connector when i did it,, but when i went to see if i had juice to the button, it didnt... but the button will kick it out of over drive when pushed, and will let it back in when pushed again...
Old Jan 4, 2003 | 01:30 PM
doodah's Avatar
so it is just the light in the button that is not getting juice..
Snapper
Dec 12, 2009 08:14 AM
Strjock81
May 8, 2006 11:24 PM
Otis
Sep 1, 2005 08:20 PM
spudwrench
May 22, 2005 08:23 AM
