now what
Old Mar 3, 2009 | 01:36 AM
george_girouard's Avatar
now what
Truck still giving me headaches checked out the fuel pump its pumping fuel at the right volume so it is ruled out. The timing of the fuel system seems to be out of wack as you pour the fuel to it, the truck seems to have a secondary humming noise. Truck is now starting to balk quite a bit in other words it hesitates some times when I pour the fuel to it and when it does it puffs dark smoke any ideas? Truck is a 01 2500 ram diesel 5 speed put a motor from an 02 in out of an automatic
Old Mar 3, 2009 | 06:20 AM
Adaminak's Avatar
Did you replace all the ECM/PCM boxes to match the manual transmission? The programming for auto versus manual is different, and they rely on different signals to make changes in the fuel delivery.
Old Mar 3, 2009 | 10:41 AM
Motor came complete the only thing we had to do was add the alternator change out the fly wheel and hook up the electronic connections. I got it checked over at the dodge dealership got a clean bill of health it ran fine for a while then started to act up.
Old Mar 3, 2009 | 12:22 PM
Checked the codes on the truck it throwing p1693 I checked all threads on this site that relate to this and none of them have identified what the code is does anyone know?
Old Mar 3, 2009 | 12:59 PM
dieselrob's Avatar
Its a companion code. You need a code reader to get the codes out.
Old Mar 4, 2009 | 08:28 AM
Adaminak's Avatar
The electronics are not compatible. The auto trucks take into account signals from the transmission and adjust engine parameters based upon that input. A manual truck doesn't give those signals, and the ECM/PCM won't be able to figure out what it should do. I'd see if you could borrow an ECM from a friend with a manual truck (or use your old one) and see if it makes a difference.
Old Mar 4, 2009 | 09:01 AM
John Faughn's Avatar
If you do not know what is wrong " NEVER " swap computers , these computers almost never go bad by themselves , a bad computer is about 99.99% made bad by something on the outside killing it , so if a solenoid or short some where else on the truck damaged the computer , then when you put another computer in there as a test/fuse , and blow it up , now you need to by 2 new computers .
Next just a lack of info makes it harder to help , as an example , you said you check the fuel pumps volume , which pump , and I would suspect you did not check the volume [ a rare tool , checking volume ] , pressure is what is usually check in diesel fuel injection , and coming from lift pump .
Did you check with a good parts house for any variation in the computer compatibility ?
moparmatt
May 1, 2015 08:49 AM
Shorts
Jun 29, 2013 09:23 PM
95ram
Jul 28, 2010 02:17 PM
ramlovingvet
Mar 22, 2003 08:32 PM
cfm3110
Mar 18, 2003 10:54 AM
