No Running Lights
Old Aug 15, 2005 | 09:57 AM
Riverjet502's Avatar
Question No Running Lights
Hi Guys
I’m having a problem with my ’92 ¾ diesel. I have lost my tail, parking and instrument lights. I have checked the fuses with a continuity meter and they check out OK. Nothing is blown fuse wise. I have looked for crimped or chaffed wires from front to rear. Kinda at a loss here. Anyone have any ideas? Could the head light switch be bad? Headlights work fine. They are on a different circuit I realize. Just wondering what else to check here. Any thoughts here?
Thanks guys…
Old Aug 15, 2005 | 12:00 PM
natstayl's Avatar
Did you check continuity with the fuses still in their cavity or out?
Nat
Old Aug 15, 2005 | 12:19 PM
I pulled all the fuses out of their repective slot from the fuse block then checked them for continuity. Then reistalled them.
Old Aug 15, 2005 | 12:38 PM
Lil Dog's Avatar
The switch?? I know just the connector on my 93 was roasted at the switch and it wasn't pretty. The switch was also toast. Had to do some soldering on the connnector to replace the spades and replaced the switch..
Old Aug 16, 2005 | 06:44 AM
neveragain's Avatar
running lights
Are there fuse links on yours or If you have the book they did break them down to A-21/22 , A-31, 32 ??? As it goes through the ignition key.
BuckyKatt
Feb 8, 2013 01:12 PM
Banzai Bob
Feb 24, 2010 12:24 AM
getrdun
Nov 26, 2008 11:46 AM
eric13
Oct 17, 2005 07:05 PM
