No Power? Low Boost?
Old Jun 6, 2007 | 06:12 PM
schoust's Avatar
Ok Guy's here's the story I did a little work on the truck and power washed the engine in areas that were grimy (around the timing case ) anyway I drove to work the next day and I was way down on power and the pyro was telling me that Iwas running very hot with very little effort and smoke seemed above normal. I have been planning on getting a boost gauge but don't have one as yet. I checked and cleaned the filter and visually inspected the intercooler rubbers and the boost line to the waste gate and all seems Ok,any ideas I'm missing my power already .
Old Jun 6, 2007 | 06:15 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Check all of your electrical plugs. Maybe water inside one of them. Clean with electrical cleaner or starting fluid (ether) and pack with dia-electric grease.
Old Jun 6, 2007 | 06:25 PM
schoust's Avatar
Sorry,should have mentioned it's a 12 valve I figured the signiture would do it.....
Old Jun 7, 2007 | 12:00 AM
Mike Perez's Avatar
You can try cleaning your map sensor (Boost sensor) I have a Amzoil filter which is similar to the K&N in that you inpregnate it with oil. too much oil in the filter and it will get drawn in by the turbo and a coating will cover your sensor. No codes will appear; I didn't clean mine I bought a new one and it fixed the problem.
MP
Old Jun 7, 2007 | 05:26 AM
schoust's Avatar
Again,this is a 12 valve Truck......
Old Jun 8, 2007 | 04:19 PM
058hamer's Avatar
how about the shutoff solinoid ? is it fully retracting the arm? thats the only elc on a stupid pump hope this helps 058hamer
dirty dozen
13
Aug 19, 2015 06:39 PM
CRToney
0
Nov 26, 2014 07:55 PM
Southtowns27
Jul 2, 2011 08:50 PM
jmlcolorado
May 19, 2010 10:30 PM
