NO power to fuel pump
Old Aug 22, 2009 | 10:58 AM
carcreations's Avatar
2001 ctd Holley blue added to factory harness. 20,000 miles since install. Truck cranked, then died. Will not start. When key is turned on, fuel pump is powered for less than 1 second, then cycles out. Changed relay, Unplugged Holley, still shows power for less than 1 second. Any ideas?
2001 dodge 3500 dually
Holley fuel pump
Edge ez
1/2" an fuel lines
Old Aug 22, 2009 | 06:04 PM
Equalizer 2's Avatar
I am working on this myself. Only my pump just quit and will not power up. When it was working it would run until pressure was built up in the line and then it would stop running until the engine started. Have you tested the power leads with a multimeter?
I am in the process of installing an Air Dog 100 but they sent me the 2005-2009 model instead of the on I need for the 2004 with the fuel filter mounted pump.
Stevie G
13
Aug 4, 2006 10:27 PM
Commatoze
19
Aug 8, 2004 09:57 PM
powerwagon440
May 25, 2003 02:31 PM
amartinson
0
May 4, 2003 01:55 PM
