No Lights
Old Jan 27, 2008 | 12:57 PM
BULL NOSE DODGE's Avatar
Exclamation No Lights
Hey yall, Thanks for reading and helping me with this. I have a friend who just called me from Dallas. He said that he has no turn signal or brake lights. Said he was using his flashers this morning because of the fog and now nothing works. He said that his running lights and head lights are working and that he checked his fuse and it was good. Any help with this would be greatly apprciated but both of us. He has a 1998 ext. cab 4 wheel drive 1 ton dually ctd. Thanks Mike
Old Jan 28, 2008 | 05:12 PM
hink's Avatar
Replace the bulbs and see what happens. That would be a cheap and easy place to start.
Old Jan 29, 2008 | 08:07 AM
smokeyram's Avatar
when yu have just headlights and running lights on the cab, its usually the headlight switch on the dash. well, ive replaced 2 on mine when it does that. $20 part, 20 minute replacement with minimal tools.
Old Jan 30, 2008 | 01:41 AM
mopar-or-no-car's Avatar
I would also suspect the headlight switch. My uncles truck is 93 (I know its way older but I don't think there were many upgrades to how they wire the lights) ctd ex cab dually so it has the cab lights and marker lights on fenders and what not, anyways he melted like three headlight swicthes in just over a month. I think its to many lights to be running through the switch maybe if it is the switch he could add some relays for the headlights to take some of the load off of the switch. Just my opinion
Old Feb 2, 2008 | 10:46 PM
Thanks for yalls input. My friend is still having trouble with it so I will pass on yalls info. Again I appreciate yalls time. Bull
Old Feb 2, 2008 | 10:49 PM
vzdude's Avatar
DTR's 'Go to Guy'
Cycle the hazard switch again. Sometimes they don't get a good contact in the off position, and that is required for the signals to work.
Do they come on and not blink? Not come on at all.....what exactly are the symptoms?
Old Feb 2, 2008 | 10:52 PM
biododge1's Avatar
maybe the flasher is bad
Old Feb 5, 2008 | 09:21 AM
Sorry about the late response. He is blowing the fuse now. He puts a fuse in under the hood and just as soon as he uses the brakes it blows the fuse. I believe the same with the turn signals. The runnining lights and head lights are the only lights that stay on.
Old Feb 5, 2008 | 10:26 AM
johnh's Avatar
it sounds like the brake light wiring circuit has a short....the brake lights and rear turn signal use the same circuit
cummins dsl
22
Jun 27, 2005 11:53 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
