no brakes
Old May 8, 2009 | 01:34 PM
skoalcowboi00's Avatar
no brakes
I got a 95 2500 12 valve 5 speed and the brake pedal is hard as a rock and i have no brakes hardly. I have oil leaking between my vaccum pump and power steering pump. Is the vaccum pump bad or what could be going on here. Thanks
Old May 8, 2009 | 04:56 PM
infidel's Avatar
The vacuum pump seal can leak oil but the pump still make good vacuum.
More than likely you have a vacuum leak not allowing enough to build up to assist the brakes.
Common leak places are under the driver's side battery where acid eats the hose to the cruise control or in the area of the fuel filter where lines can accidentally get disconnected.
Old May 8, 2009 | 06:51 PM
johnh's Avatar
are the brakes on a '95 vacuum assisted??
Old May 9, 2009 | 06:13 AM
JohnBer's Avatar
yep they are.
Old May 9, 2009 | 02:34 PM
BigIron70's Avatar
Cummins Guru
I would check the hose from vac pump, if it is soft and oil soaked replace it.
wildcargo
Nov 29, 2005 04:20 AM
95black2615
Aug 22, 2005 09:21 AM
JImbo1
13
Apr 18, 2003 06:44 AM
