No brake lights on '07 5.9ltr
I am new to this forum but seen alot of really good tech help here. I have a problem with my 2007 5.9 litre, My brake lights have stopped working and the dealer has replace the TIPM 3 times now and i got my signals and daytime running lights back but still no brake lights... any help would be much appreciated asap. The third lights up top works still so kinda confused???
Although it's warranty I understand you being concerned about it as a safety issue, no fun getting rear ended because someone didn't see you stopping.
Now, I would look for the harness going from the ccab to the rear of the truck, with the can bus you have it will be smaller bundle of wires would be my guess, now follow the harness and look for a plug or some type of connection. My guess is that somethign is loose or almost unpluged. Start at the front and follow to the rear. If you do not find it that way probably a relay or fuse in the power center. If it isn't obvious wait till tuesday and get to the dealer and let them worry about it.
Having said that, the vehicle MUST still be maintained in proper working order. This is a loophole that some will use, in particular if the accident was at night!
Am I contradicting myself...yes and no...
Tony
3rd brake light is run straight from stop switch to light. The stop / turns in the bed are run from the TIPM. Sounds like the dealer is missing a problem and just getting you by until the problem happens again. Fix the cause, not the result! Probably a wiring problem. Does it happen only after towing a trailer? Have any other lighting installed ( aftermarket?) or anything else like remote start or something? Look at all the wiring for any rub throughs. Have a fifth wheel or gooseneck installed? They could have nicked a wire as well.
adamsmasher
Apr 7, 2015 07:03 AM
polaris800sp
Nov 13, 2008 05:35 PM
proudpapa97
May 4, 2008 06:50 PM
CHarlan
Aug 6, 2003 08:40 PM
