No Boost
I was coming back from the coast pulling my 9,000 lb. fifth wheel trailer, was
pulling a slight hill. Was still in overdrive, pyro was sitting at about 800, boost was near 20 when I heard a sound like a tire blew out. There was a lot of smoke in my rear view mirror. I pulled over and checked all 10 tires, and they were all fine. When I took off again I had no boost, no power.
I have checked the intercooler and the line coming to it and the line going to the engine. I have taken the turbo to a turbo shop and they tell me it looks real good. I have no boost and no power. When the truck starts to pull a little the pyrometer raises quickly.
Either a boot is blown, leaking at a clamp or the intercooler is split. Don't know what year. Some years had plastic cooler connections and are bad about splitting. Doubt 20 PSI would blow a metal cooler. JMHO
There are some reasonable priced aftermarket coolers to be had.
Pressure test it
Rob
No Boost
You responded pressure test it. And yes that is a very good responce. I have a leak in the intake under the toaster or pre heater or what ever the thing is that warms up the intake for a cold start. Cummins don't have glow plugs they have this heater, toaster, instead. Well any way after removing the turbo and having it checked out. And after checking the charge tubes and boots I finally pressurized on the inlet side of the intercooler and heard the sound of leaking air. Soapy water helped identify the area of leakage.
Sounds like some of the previous posts helped and I am glad you are getting it figured out. If you get the time, could you explain how you pressurized it etc? Thanks much.
No Boost
I went down to a local plumbing store and purchased two 3 inch plastic end caps that one would glue to 3 inch plastic pipe ends. I duct taped one of them after drilling a small hole in it to the inlet side of the intercooler. I then stuck my air hose nozzle into that little hole and shot air into it. I made sure I only had about 30 pounds of air in my tank. Of course the duct tape did leak a little but using soapy water from a spray bottle I found the leak. Under the manifold pre heater there is a long narrow plate. I ended up replacing the gasket for that plate and now I have boost again. I pulled my turbo and pulled the charge lines off and did a lot of extra work that was not needed. All I had to do was pressurise the system and check for leaks.
But mine is different. You need a short piece of 3" pipe, a 3" cap drilled and tapped with a 1/4" port for the air hose and 3" ID X 3" OD rubber hose clamp coupling ( $9 Home Depot)
I actually tapped two ports on my cap, one for a pressure gauge and on the other I used a tire valve for filling.
Replacing my intake gasket sure helped out my 2000 24 valve. I have heard things like "better use lock tite on those cap screws or else they will eventually backout." I don't know but I seem to develope more boost now that I did before the bursting of that intake gasket. I am wondering if I didn't have a seeping leak for a while before the burst. Does any one know about using lock tite?
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
Palmetto_kid
Jan 16, 2004 02:21 PM
