New U-Joint
New U-Joint
I have a 2007 dodge 2500HD 5.9L 4x4 and no one can get a rear U-joint except dodge and the closest dealer is 2 hours away. Is there any where else I can get one ? and what is the part number
thanks
nathan
thanks
nathan
I found 2 from summit that are prescion u joint. I have there measerment are
American Axle - style 1485
bearing cap Dia. 1.375 for both axis's
width overall as 4.187 for both axis's
American axle - style 1415
bearing cap Dia 1.188 for both axis's
Can anyone tell me which or if either of these is correct
thanks
nathan
thanks
nathan
Also,,,try looking here. Is your a 1 piece, or 2 piece shaft.
http://www.newmoparparts.com/mopar-parts.htm
Here's another one. I think the problem you're having is because of it being so new,,,there's not a listing.
Is your's a mega cab, or manuel. If not,,then it's the same as mine. Wich would be Precission # 330A. That # is on napa. But they don't show a 07. Look through this catalog and you'll see a 07 listing, wich is the same as 05, you'll be able to figure it out. But it's not in precission number's. Hope all that make's sense.
http://neapco.com/n_products-catalogs.php
mine is an auto and a quad cab. I went to the summit racing and found there part number and with that is a list of other vehicles that use the same one. So i Just got a u joint for a different vehicle that uses the same part number.( a 2003 v10 auto quad) Also alot of chevy DuraMax use the same one, most of those however are greable, but I have not problem with that
thanks for all the help
nathan
nathan
if you go to the summit racing website and go to the persision U joint part, there is a really good cross referance. For both all of them. I got the measurment and compared and ended up ordering a ujoint for a 2003 chev 2500 duramax. There is more then 400 trucks that this u joint fits, and the mega cab or manual tranny have have some other vehicles that use the same u joint's also
thanks
nathan
thanks
nathan
I got it from a local parts dealer and they are installed and perfect. It was the 330a. If you have a a mega cab or a quad long box (3 peice drive line) you need a 351a. If you want one for the mega cab you want to order this peice, because it is avalible in store's and is not an ONLY Dealer Item. ( And all these are steel and greasable)
Part number PCN - 351A
Universal No
Make DODGE
Model RAM 2500 PICKUP
Liter 5.9
CID 359
Engine Size 5.9L/359
Beginning Year 2003
Ending Year 2003
Engine Family Cummins diesel
Engine Type L6
Drivetrain 4WD
Universal Joint Position Center
Application Notes 6-speed manual transmission.
and for a Quad Cab w/ short box you need
PCN-330a
Universal No
Make CHEVROLET
Model SILVERADO 2500 HD
Liter 8.1
CID 496
Engine Size 8.1L/496
Beginning Year 2004
Ending Year 2004
Engine Family Chevy big block Gen VII
Engine Type V8
Drivetrain 4WD
Universal Joint Position Rear transfer case
Application Notes Regular cab with 4-speed automatic or 5-speed manual transmission.
Universal No
Make DODGE
Liter 5.9
CID 359
Beginning Year 2003
Ending Year 2003
Engine Type L6
Drivetrain 4WD
PCN-330a
Universal No
Make CHEVROLET
Liter 8.1
CID 496
Beginning Year 2004
Ending Year 2004
Engine Type V8
Drivetrain 4WD
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
