Need a torque spec ASAP
I need the torque spec for the main bearing cap bolts for a 2000 24 valve. They are a 12mm bolt. I had to drop it to sneak the tone ring in there.
It should be a torque + 90*. Any help would be appreciated.
Thanks,
Mike
Thanks,
Mike
TORQUE CHART 5.9L DIESEL ENGINE
DESCRIPTION N·m In. Ft.
- Lbs. Lbs.
Battery Cable to Block - Bolt 77 - 57
Belt Tensioner - Bolt 43 - 32
Block Heater - Element 43 - 32
Camshaft Thrust Plate - Bolts 24 - 18
Charge Air Cooler - Bolts 2 17 -
Clutch Cover-to-Flywheel - Bolts 23 - 17
Connecting Rod - Bolts - - -
Step 1 35 - 26
Step 2 70 - 51
Step 3 100 - 73
Cooling Fan to Fan Clutch 20 - 15
Main Bearing - Bolts - - -
Step 1 60 - 44
Step 2 119 - 88
Step 3 176 - 129
Crankshaft Pulley/Damper - Bolts 125 - 92
Crankshaft Rear Seal Retainer - Bolts 9 80 -
Crankshaft Tone Wheel - Bolts 8 71 -
Cylinder Head - Bolts - - -
Step 1 80 - 59
Step 2 105 - 77
Step 3 Verify 105 - 77
Step 4 Rotate All Bolts 1/4 Turn
Cylinder Head Cover - Bolts 24 18 -
Exhaust Manifold - Bolts 43 - 32
Fan Clutch Mounting to Fan Hub 57 - 42
Fan Hub Bracket - Bolts 24 - 18
Fan Hub Bearing - Bolt 77 - 57
Fan Pulley to Fan Hub - Bolts 9 84 -
Fan Shroud Mounting - Bolts 11 95 -
Flywheel - Bolts 137 - 101
Flywheel Housing - Bolts 60 - 44
Flywheel Housing Access Plate - 24 - 18
Fuel Delivery Lines (High Pressure) - - -
At Pump 24 - 18
At Cylinder Head 38 - 28
Fuel Drain Line - Banjo 24 - 18
(rear of head) - - -
Fuel Filter Cannister - Nut 14 - 10
Fuel Injection Pump Gear 170 - 125
Retaining - Nut - - -
- Lbs. Lbs.
Step 1 35 - 26
Step 2 70 - 51
Step 3 100 - 73
Step 1 60 - 44
Step 2 119 - 88
Step 3 176 - 129
Step 1 80 - 59
Step 2 105 - 77
At Pump 24 - 18
129 ft lbs is for a 12 valve with 14mm main cap bolts. I have all the 12 valve manuals, 1 says 44, 88, 129, and the other is 44, 66, then 90*.
According to my reference material 95 ft lbs in the recommended torque on a 12mm fastener of that grade.
03 shows a torque similar to what you stated, but......it's for an '03. Here's the chart.
TORQUE
TORQUE CHART 5.9L DIESEL ENGINE DESCRIPTION N·m In. Lbs. Ft. Lbs.
Connecting Rod—Bolts
Step 1 30 — 22
Step 2 60 — 44
Step 3 Rotate 60 degrees
Crankshaft Main Cap—Bolts
Step 1 50 37
Step 2 80 59
Step 3 Rotate 90°
Cylinder Head—Bolts
Step 1 70 — 52
Step 2 Back off 360 degrees
Step 3 105 — 77
Step 4 Verify 105 — 77
Step 5 Rotate All Bolts 1/4 Turn
Cylinder Head Cover Bolts 24 — 18
Breather Cover Bolts 24 — 18
HPC Nut 50 37
Fuel Delivery Lines—Banjo 24 — 18
Fuel Drain Line—Banjo 24 — 18
Fuel line—rail to cylinder head 30 — 22
Fuel line—pump to fuel rail 37 — 27
Injector fuel line brace 24 — 18
Fuel rail holddown bolt 24 18
Oil Pan—Bolts 28 — 21
Oil Pan—Drain Plug 50 — 37
Oil Pressure Regulator—Plug 80 — 59
Oil Pressure Switch 18 — 13
Oil Pump—Bolts
Step1 8 — 6
Step2 24 — 18
Oil Suction Tube (Flange)—Bolts 24 — 18
Oil Suction Tube (Brace)—Bolt 43 — 32
Rocker Arm/Pedestal—Bolts 36 — 27
TORQUE
Step 1 30 — 22
Step 2 60 — 44
Step 1 50 37
Step 2 80 59
Step 3 Rotate 90°
Cylinder Head—Bolts
Step 1 70 — 52
Step 3 105 — 77
HPC Nut 50 37
Oil Pump—Bolts
Step1 8 — 6
Step2 24 — 18
svanni
Mar 24, 2008 03:53 PM
DODGER BOMBER
May 25, 2007 09:33 PM
