Need Help Wont Start!!!
Old Jul 3, 2005 | 02:13 PM
jimc11's Avatar
2005 stock. Fuel filter replaced 2000miles ago. Today stopped at my parents and my father tried starting. I thikn he mashed the pedal as he did. Well it wont start now. Tried letting it sit and couple hours...Noticed when trying the the only gauges that move when trying to start are the tach and speedo. Fuel gauge needed etc never moves. Tried adding 10gal fuel and still nothing. The low fuel light still comes on (I know it wasnt empty) Turns over and jumps and rattles but never fires. Seems like no fuel getting up. But with the gauges not working either I am clueless. Any help before I have it towed? Thanks
Old Jul 3, 2005 | 02:18 PM
darkvader's Avatar
make sure fuel filter is full, if so make sure lift pump is running when you turn on key, then crack pump and inlector lines. make sure fuel shut off sol wire did not fall off
Clark
Old Jul 3, 2005 | 02:21 PM
jimc11's Avatar
Dumb Question...Any idea where the fule shutoff sol wire is. Ill go check these thinghs and check back in here in about an hour or so....THANKS>>>
Old Jul 3, 2005 | 04:02 PM
darkvader's Avatar
not real sure on new ones, think there is a relay on firewall and there should be a wire on rear of pump around fuel inlet. Woll try to find illustration
Clark
Old Jul 3, 2005 | 04:23 PM
handymantim's Avatar
These new trucks are supposed to be self-priming. Try bumping the starter several times. Each time you bump the starter you should be able to hear the electric fuel pump run for about 20 seconds. Your electric fuel pump is in your fuel tank on the 2005 but you should still be able to hear it. After several starter bumps, try to start it. Don't run the starter for more than 30 seconds.
If that doesn't work, you can get the codes out of the computer by turning the ignition switch on/off/on/off/on and then read the codes in the odometer window.
Don't be too harsh on your dad. Mashing the pedal to the floor shouldn't make any difference.
TNDODGE
Sep 13, 2012 01:38 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
jimc11
Jul 5, 2005 01:52 PM
Desert Diesel
Dec 5, 2002 08:53 PM
