Need to get injectors out NOW HELP!!!!!!!!
Old Feb 23, 2011 | 03:25 PM
Spencer Denton's Avatar
06 6 speed 3500 im tryin to get injectors out could someone walk me through it?
Old Feb 23, 2011 | 03:45 PM
Rpainter's Avatar
What are you stuck on?? There are lots of references with pictures available.
Old Feb 23, 2011 | 05:45 PM
cbrahs's Avatar
Remove valve cover,
remove injector lines
remove nut holding crossover tubes and pull crossover tubes
remove exhaust rocker arms
remove injector hold down bolts
remove injector harness
pull injector up with puller (i have used a plastic interior pry tool before in a pinch)
Old Feb 25, 2011 | 08:11 PM
Rpainter's Avatar
Originally Posted by cbrahs
Remove valve cover,
you forgot the rail, the intake horn, and the map sensor
Old Feb 25, 2011 | 10:13 PM
Bark's Avatar
Spencer Denton: I have never replaced them so dont know anything but advanced search is your friend. Go to search than hit advanced search. Under "search by keyword" type in "remove injector". Under "search in forums" select 3rd gen engine and drivetrain ->2003-2007. You will probably find some good info in those threads. I am trying to find the one Rpainter was referencing (it had pictures).
moparmatt
May 1, 2015 08:49 AM
snowmanx
May 23, 2010 09:18 PM
crobtex
Jan 13, 2005 08:33 PM
converteddzlr
Feb 11, 2004 01:22 PM
