To Much Oil
Old Feb 13, 2004 | 05:31 PM
DODGE4X4's Avatar
Angry To Much Oil
I just got my truck back from the Dealer having a new oil pan gasket put on and they overfilled the oil by at least a quart . Do I need to drain the oil and put the correct amount in? Or just go down the road.
Old Feb 13, 2004 | 05:37 PM
MnTom's Avatar
A quart? Shoot, just go down the road. A quart over will not hurt anything.
Tom
Old Feb 13, 2004 | 05:39 PM
quantrill88's Avatar
https://www.dieseltruckresource.com/...t=oil+overfill
not the first time its happened
i would think you could also go back to the dealer and make them do it...
Jeff
Old Feb 13, 2004 | 05:41 PM
DODGE4X4's Avatar
Thanks for the fast reply, I think it is just a quart but it might be more. Will it just blow out the crank case hose??
Old Feb 13, 2004 | 06:18 PM
infidel's Avatar
As long as there's not so much oil that the crank whips around in the pan oil it will be fine. If the crank is in the oil it will be foamy on your dipstick right after running it.
I always use 12 qts on an oil change, a little overfull on the dipstick, beats having a quart left over in a gallon jug to just use 12 qts.
Old Feb 28, 2004 | 09:51 PM
AggiePhil's Avatar
When I first got my truck, I got the oil changed at a grease monkey place and they overfilled it. I heard them say "12 quarts!" when they were putting the oil in. Well, it was pretty high on the dipstick and the oil pressure gauge was reading kind of high. So I called the dealership and they said that it holds 11 qts. (10 if you aren't changing the filter too) and that I should go back and have them drain some out. That's what I did and I now rest better.
Old Feb 29, 2004 | 12:40 AM
Haulin_in_Dixie's Avatar
I have used three gallons on a oil change from the time the truck was new. Never had a problem. With my heavy towing, the oil capacity is too small so I tried it and it went well. It is only one quart over, no real problem.
Old Feb 29, 2004 | 01:26 AM
Dieseldude4x4's Avatar
When I was running dino oil and changing it on a regular basis, I always used three gallons. Never had a problem with almost 400,000 miles on three different trucks.
1$Chuck
Jul 15, 2011 05:00 AM
bobinyelm
13
Mar 4, 2010 08:19 PM
Jim5870
Aug 19, 2009 10:33 AM
Lu
Jun 24, 2003 08:57 AM
MR. GADGET
Apr 24, 2003 02:51 PM
