Low voltage to MAP/IAC
Old Jan 22, 2005 | 04:35 PM
Meierznutz's Avatar
Dealer coded the computer and said it was a bad MAP and IAC. Got parts FED EX'd to house and installed. Tried to clear codes with scan tool but they wont clear. HELP, 45 driveways to plow and it's snowing!!!! 8 to 18" expected.... this will cost me a fortune!!!
Old Jan 22, 2005 | 08:44 PM
Meierznutz's Avatar
Got the code to clear... for ten seconds. Truck is in safe mode, no *****, no boost over 5#, no more than 30mph. Idles great!!! I changed the fuel filter (couldn't hurt, right?) and found out that when the truck is COLD, it runs ok. Some bucking but has power. After it warms up, bucks a few times and goes to safe again. WHAT IS THIS????? Any ideas folks? I'm stumped.
Old Jan 23, 2005 | 06:33 AM
chouchins's Avatar
I think the 5 volt supply for the MAP comes from the ECM. You should take a voltmeter and check for 5 volt at the MAP sensor first. You did not list codes which would have helped. Good Luck
Old Jan 23, 2005 | 12:43 PM
John Faughn's Avatar
Generaly low voltage bad ground , no voltage no power.
12-93 2500 4x4 auto cummins from this site 2 wks ago $7500. clean , love it.
Old Jan 24, 2005 | 07:04 AM
Meierznutz's Avatar
checked both sensors, theyre good, wireing good, ECM is shot. Went into Safe/Limp mode. Have to get a new one today. Mopar Performance Parts Cat lists a Hi-Perf one, have to see if they can get that, although it may just be the stock HO in disguise. Thanks to those that replied....Chris
imbodie
21
Jan 8, 2024 08:49 AM
Bad-Duvall
Oct 9, 2008 12:52 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
Gene007
Apr 25, 2006 06:50 PM
