Interior light problem
Old Oct 2, 2006 | 07:16 PM
MOUSE's Avatar
During bulb replacement of glove box light connector shorted and lost the cargo, interior, hood, raido. all fuses are good yet have no power on the pink wire. can anyone tell me what other components are in the light circuit.
Old Oct 2, 2006 | 07:49 PM
XLR8R's Avatar
Did you check the PDC and the interior fuse panel?
Old Oct 2, 2006 | 07:55 PM
MOUSE's Avatar
the pdc is ok and all the fuses are good
Old Oct 2, 2006 | 08:05 PM
handymantim's Avatar
Somtimes fuses can look good but still be blown. Sure seems like you have a blown fuse.
Do you have a volt/ohm meter? Use that to make sure your fuse(s) are good. If you don't have a meter then replace the suspect fuse with a new one.
Old Oct 2, 2006 | 08:16 PM
MOUSE's Avatar
checked fuses with a vom. all fuses are good, will get a copy of the schematic tomorrow and track it down, that is strange to me to because all the fuses check good will have to check it at the first connector out of the fuse panel for voltage.
stratos201proxl
Jan 16, 2014 11:04 AM
PoorMansCat
Nov 29, 2007 10:00 AM
miketriton
Jun 16, 2006 08:21 AM
Vintage Empire
Dec 20, 2005 10:02 AM
patriot pearl blue
Dec 29, 2004 06:47 AM
