Intake pre-heater gaskets
Old Jun 19, 2006 | 05:28 PM
Mslaughter's Avatar
On the intake pre-heater I have a boost leak around there so I bought new gaskets. When I installed the new gaskets I put down a gasket, then pre heater, then the other gasket, then the strap, the torqued down the intake. Is that right or does the strap touch the pre heater then gasket goes on top? It still leaks a little even with the new gaskets.
Old Jun 19, 2006 | 09:44 PM
J BODY's Avatar
intake/gasket/grid heater/gasket/intake/strap i believe. That's how it is on most the 24 v's I work on.
Old Jun 19, 2006 | 10:15 PM
Mslaughter's Avatar
So the strap goes on the very bottom then. I'll re-arrange it tomorrow and hopefully it'll fix my little leak. Thanks
Old Jun 19, 2006 | 11:47 PM
J BODY's Avatar
no no no! that was from the bottom up! Strap will be on the top and the bolt will run through it. It should not be sandwiched between any componants.
Old Jun 20, 2006 | 03:34 PM
Mslaughter's Avatar
Thanks J body, moving it fixed the leak. Truck runs much better now
bradler
Jan 13, 2009 02:46 PM
stock600
Mar 10, 2008 04:33 PM
mojo_jumper
Feb 26, 2008 06:03 PM
6-Pack
Jan 28, 2008 03:30 PM
